| Forum |
#1 (permalink) |
Well, it chanced upon me, many symbian users miss out on fully utilizing their fones, coz they nv knew. Peeps, share wif everyone tips and trick that u know of symbians! Tip 1 : Do u noe how to use the edit button (abc or pencil button)? Heres how... in the inbox for example; u wanna delete multiple sms, simply hold the edit button, scroll down, and then, press c to delete the marked sms. The edit button can also b used to copy and past text in sms, simply hold it and scroll across, choose copy. pretty good for placing song names in ngages Tip 2 : **** happens, on a smartphone, its inevitable u do something wrong, and tis calls for a format of fone. to format the fone, press *#7370#, then enter the lock code, which is the sec code of the fone. NOTE: batt must b full, else if format is disrupted by low batt, consequences will b disatrous I heard the code *#7780# works too, pretty much the same i tink. for 6600 users, to format the fone, theres an alternative way. Press and hold <3>, <*>, and the buttons, then power on fone, keep holding on the 3 buttons, till u come to a format screen. tis method ONLY works on 6600, and need not enter the sec code. BUT sec code wun be reset to default 12345. Tip 3 : TO NGAGE USERS; Did u know u can install .sis files simply using the cable given? Juz plug it in, place the .sis file anywhere on e: (the mmc), not in any folders, root of e:, disconnect, then look for it in manager. Tip 4: Save on battery and system memory being used by regulary checking the task manager which can be accessed by holding down the menu button!! Tip 5: Type *#06# to display your IMEI serial number, very valuable for the unlocking your phone to other sim cards Tip 6: Type *#0000# to view which firmware version you are running __________________ Tip 7 Operator logos Use a filemanager like FExplorer or SeleQ to add the folders: "c:/system/Apps/phone/oplogo". Add a .bmp picture to folder "oplogo" and restart your phone! The .bmp picture size needs to be: 97 x 25 pixels Tip 8: Check if the recepients phone is on Delivery reports or Type *0# your message in the message composer window space then write your message, the recipient will not see the star zero hash bit - just the message When they read it it will relay a message back to your fone showing the time they recieved it. (haven't yet tried it myself though) Tip 9: BlueJacking First up, you need to know what Bluetooth is. There are lots of types of modern devices that incorporate Bluetooth as one of their many features. PDAs, mobile phones and laptops are a few of these modern devices. Bluetooth means that Bluetooth enabled devices can send things like phonebook/address book contacts, pictures & notes to other Bluetooth enabled devices wirelessly over a range of about 10 metres. So, we've got past the boring part. Now, using a phone with Bluetooth, you can create a phonebook contact and write a message, eg. 'Hello, you've been bluejacked', in the 'Name' field. Then you can search for other phones with Bluetooth and send that phonebook contact to them. On their phone, a message will popup saying "'Hello, you've been bluejacked' has just been received by Bluetooth" or something along those lines. For most 'victims' they will have no idea as to how the message appeared on their phone. #10: A soft and Hard reset A Soft-reset - the process of resetting all the settings of the phone to the factory default! No applications are deleted! A Hard-reset is like formatting a drive! It does format the memory. Everything that has been installed after the first use of the phone is deleted! It will recover the memory of the phone to the state you purchased it! It is done by inputing the following code: *#7370# NOTE: The battery must be full or the charger has to be connected to the phone so that it does not run out of power and make the phone unusable. #11: Formats of images supported ones: JPG UPF GIF87a/89a WBMB MBM TIFF/F PNG EXIF Smart Launcher trick: Install Smart Launcher and open it. Go to Options, Settings and put Launcher ON. Now plug in your charger and switch off your phone. Wait untill the battery meter appears and short press the Menu button (don't hold). The menu should appear and now you can have 3,5 to 4,5 MB free RAM! (Hold Menu button to check RAM). The trick is that with the charger plugged in, the phone must get a minimum software support for charging, even when the phone is switched off. And somehow Smart Launcher has still got it's shortcut running and that's the Menu button. So when you press the Menu button, you go directly to the Menu without any other phone tasks running in the background so you trick the phone and you have more free RAM! Note: when you unplug the charger, the phone will switch off Post ur replies |
#3 (permalink) |
Yeah...Good info
but u culd hav made a single thread for Symbian stuffs.
# 19000 Members & Counting .... Click Here To Join India\'s Second Largest Community http://www.sansite.info/ |
#4 (permalink) |
Walking, since 2004.
I don't know if u know the tips and tricks for mobiles, but i know that u know the tips and tricks for getting banned....
all fuc*** threads just copied from this site... dude it duznt take time to post a source.... atleast have the shame and the courtesy(which u don't have) to credit some other person's work http://nokiafree.org/forums/t63968/h/s.html
Mumbai, I miss you. |
| Bookmarks |
| Display Modes | |
