Old 04-12-2006, 06:49 AM   #1 (permalink)
Pravas's Avatar
Lightbulb Need Multi Messenger For Yahoo
Hi friends, if you want to try a multi login yahoo messenger then give try.It works for my latest version of yahoo messenger.
Download from this link :-
http://www.softpedia.com/progDownloa...oad-19851.html
Oh how to install then follow the steps below:-
1>First Of All Extract The file To Any Local Drive Of Your PC.
2>Double Click The Setup File it shows " Welcome To Patch It v2.0 setup Wizard" >The click Next.
3>Then It ask for installation directory, Let it be default or can change the path if u wish to. And select "Just Me" or "Everyone" in "install patch it v2.0 for yourself, or for anyone who uses the computer" Dialog box> Click next
4>Click next again in the screen that appears.(It will install the software)
5>Finally when the setup is finished click close.
6>You can see a "patch it v2.0" icon on the desktop. Double click to execute it.
7> Now When You Execute it , then you will have to locate the yahoo messenger.exe file .
8>After you that any time you click on the "patch it v2.0" on the icon present on the desktop,,,,you will get n times of multiple yahoo messenger.
Enjoyyyyyyyyyyyyyyy
Pravas is offline
Old 04-12-2006, 01:30 PM   #2 (permalink)
keves2002's Avatar
Default Re: Need Multi Messenger For Yahoo
*Wrong Selection , Read the Forum Rules also
Tip: Save time by hitting the return key instead of clicking on "search"
keves2002 is offline
- by Krow
