Old 04-01-2005, 01:32 AM   #1 (permalink)
Default OUTLOOK EXPRESS NOT WORKING PROPERLY ALL OF A SUDDEN !!!
Friends,
my outlook express has stopped downloading mails and also sending them all of a sudden though it was working flawlessly for alomost 2 years withou any disturbance.
by the way, i did installed the trial version of NAV 2005 from Digit CD, after which i haven't been able to do my normal POP3/SMTP even once.
please help me out of this, why this may have happened ??
nicole2208 is offline
Old 04-01-2005, 10:42 AM   #2 (permalink)
tuxfan's Avatar
Trial versions of NAV would be pretty useless I guess. Just uninstall it and it might start working.
Alternatively, check out the mail settings in NAV.
tuxfan is offline
Old 04-01-2005, 06:55 PM   #3 (permalink)
 Macboy
goobimama's Avatar
Default thunderbird
Try installing thunderbird. it is a very good email client and very very versatile. Looking at outlook, I feel like a powerful businessman now that I have thunderbird.
Just after installation, thunderbird offers to import your mail and settings from Outlook, express, eudora and some others and it does this automatically.....hope it works..
Milind
[and while you are at it, use mozbackup to backup emails and settings in thunderbird and firefox]
I'm like a bird...
goobimama is offline
Old 04-01-2005, 08:49 PM   #4 (permalink)
most important NAV 2005 su*** just too heavy on resources...
hmm.... try these...
go to NAV options >>
then to email scanning option >>
uncheck the foll two >>
scan incoming email
scan outgoing email
restart the pc,try out !!!
if still its not working,uninstall NAV,then go for system restore ((for XP))
grinning_devil is offline
