Old 03-12-2006, 04:51 PM   #1 (permalink)
maharajadhiraj's Avatar
Default .AA and .AB files???
Guys I recently downloaded 2 split files which had the extension .AA and .AB......How do I combine them to get the file????
maharajadhiraj is offline
Old 03-12-2006, 07:42 PM   #2 (permalink)
dissel's Avatar
Default Re: .AA and .AB files???
I don't know what you try to download....but if it something warez stuff uploader upload those file in many odd format...because to avoid the restriction of the uploading site/service.
In that case if you rename(rename must be done from command prompt) that you can get the original file.
expl:-myfile.aa --> myfile.mp3 (say the file is a mp3 song)
dissel is offline
Old 04-12-2006, 12:07 AM   #3 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Hmm.. You can append them using good old Copy command.
Try this:
Start > Run > Cmd {Press Enter}
Navigate to the folder where files exist and enter this command :
copy *.aa+*.bb *.zip
If you think that resultant file is a zip file. If you think its an mp3 file then just put *.mp3 instead of zip.
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 04-12-2006, 01:23 PM   #4 (permalink)
The Researcher
Use the combine software for the this type of splits. Generally uploaders specify and give link to the special kind of splitting software that they use. Otherwise try to open any of the file using any of the compression utilities like winzip, winrar, powerarchiver etc. If it can be opened by these, then any of the file would open and then you can extract them.
Ramakrishnan is offline
Old 04-12-2006, 06:25 PM   #5 (permalink)
dissel's Avatar
oh!!!!!!!
Now i got the point....you download a split archive..
Use File SJ......
It is a file splitter + Joiner Program.
Download it and follow the instruction.... and it is a free ware.
dissel is offline
- by Krow
