Originally Posted by amit2005
well that's why i asked u people...cuz i don't want to waste a dvd
well nero is a very good Software... u should try that... i use it.. many others use it.. its good..
and about watsing DVD... umm.. try this, 1st for Test at the time of burning change the Recording device to
Image... and save (virtual burning) as ISO... then install
Alcohol 120% to creat a virtuall drive and load the ISO as a Virtual DVD to check whether every thing is allright or not... if yes then u just burn that ISO to a Physical DVD
