| Forum |
#1 (permalink) |
Well i have just purchased a PC for my friend and it is giving a problem i am not able to reach to any conclusions please assist me in what to do. Well after sometime of starting the PC around 1 or 1+1/2 Hour Later the Powersupply fans rotate very fast and a "Ghroooooommmmmmm" sound comes from the cabinet and the air given out is very hot. what exactly does this indicate. I am really tensed what exatly is happening and causing such a sound. But when i keep a hand pressed on the top part of the cabinet on the portion where the powersupply is located the sound vanishes.I even tightened all the screws of the power supply and even balanced the cabinet using paper peices so that the cabinet is not shaky.Also if i shutdown the PC for 4-5mins and restart thePC the sound vanishes. But this is a temporary solution. All you experienced guys please give me a solution to this problem it is making my head go "Ghroooooooommmmmmmm"..Is there a defect in the system or a electricity problem or powersupply problem. Its hardly 2-3 Days i have purchased a PC for him. The Configs ~~~~~~~~ Intel D915GAV + Intel 3.0 GHz Kit Power Safe 400Watts Power Supply - Gold Plated Transcend DDR 400Mhz 256MB Ram Samsung 17' SyncMaster 793s IKey PowerKey Kbd + IKey Optical Mouse Creative Inspire 2.1 Speakers Segate 80GB SATA Sony DVD Writer 16x Dlink 56Kbps Modem Samsung Floppy Drive Ibox Cabinet Urgent Replies Please |
#2 (permalink) |
moreover i think therez been a post regarding fan noise...search it...!! |
#3 (permalink) |
Hey grinning_devil
The post you are refering is this http://www.thinkdigit.com/forum/view...ight=fan+noise But the PC is neither a P3 nor a OLD one its barely 2-3 days old how come the Fan be having problems. There is some other problem |
#4 (permalink) |
An experienced tech sitting down with you at your table may be able to diagnose your problem in a short time, but for that same tech it's often difficult to pinpoint the problem from verbal descriptions alone.
First, you said that you purchased the computer from a friend. Are you quite sure everything's brand new ? Even if it is, there's always the possibility that you're unlucky enough to have a less than perfect component. I've had problems with a few SMPS'es that came with 'ibox' cabinets. Some went dead within a few minutes (blown 5V rectifier), with some others the fan failed within a few weeks. Secondly, your SMPS may be fitted with a temperature-dependent fan regulator. In such a case, the fan will run at low speed until a certain temperature is reached, after which the speed will automatically increase. Even if that's the case, it should not give out a loud sound or vibrate excessively. Either the fan is faulty or it's being supplied with an abnormally high voltage. Since you said the rattling sound can be stopped by placing a hand on the cabinet, it could be that the fan is OK, but something is a bit loose somewhere in the cabinet. This is one of those things that an experienced tech can probably isolate quickly, but difficult to diagnose from a distance. Try to determine exactly which part is vibrating. BTW, it's normal to have hot air blown out. That's what the fan is supposed to do. If you have some experience with a soldering iron, you could try replacing the fan. They're cheap enough. |
#5 (permalink) |
hey pimpom
u got it wrong i have purchased a system for my friend. The power supply is not the one that comes with ibox I have purchased the power supply seperately and its one of the best. "Power Safe - gold plated - 230V" currently the system is sent for analysis to a engineer and i will let you know about the further development. may be i should do a research on the power supply but i want to know what you feel might be wrong. |
#6 (permalink) | ||||
Do you have proper airflow paths both inside and outside the cabinet ? That will ensure that there's no excessive climb in temperature. |
#10 (permalink) | |
| Bookmarks |
| Display Modes | |
