Originally Posted by sandeep bhatia
(2) I have listen frm sum of my friends that we can change the format of any video songs from the command prompt section without using any softaware. If yes, then plzz tell me that how can I change my .dat format video songs to .mpeg format ????
ooppss... thats not possible...
what u can do is just change the extention from .avi or .dat to .mpeg ... but certainly that will not going to change the Encoding format....
u need the help of a converting software to change the encoding format...
