Old 30-11-2006, 09:47 PM   #1 (permalink)
I draw every day
yash's Avatar
Default Repair dvds with write error, make them resusable?
I remember using a software called direct cd that came with the roxio disc with my lg cd writer. It repaired my discs that were spoiled by buffer underrun error.even though it cant make it completely usable, it would let me use some ammount of space on the recordable disc. I`m just wondering if any software of the kind is available for dvds too.. my moser baer dvds were spoilt by nero saying "illegal disc" I dont have any idea what the heck that means!
Kisne roba mera tobat.
yash is offline
Old 05-12-2006, 08:16 AM   #2 (permalink)
I draw every day
yash's Avatar
Default Re: Repair dvds with write error, make them resusable?
I dont really know HOW it does it, but I remember it could use the cds that were spoilt due to buffer underrun and could not be used by other writing softwares. so basically it doesnt fix them, but it had a workaround for using those discs.
yash is offline
Old 05-12-2006, 02:08 PM   #3 (permalink)
kl_ravi's Avatar
If you are running windows XP, the built-in CD burning plugin helps sometimes whenever I get a "power calibration error".
Don't know if this works for Buffer underrun also because My writer has buffer underrun protection.
While burning using the NERO -Express, If I get a power calibration error, My writer writes Lead In-Lead out and says burn process failed. For me it means I cannot write data onto this CD anymore ....
But using the IMAPI CD burning plugin, i can write data onto such CD's. Just give it a try.
Everything that follows is a result of what you see here...!!!
kl_ravi is offline
Old 10-12-2006, 03:08 PM   #4 (permalink)
I draw every day
yash's Avatar
Can you give a link to download that plugin from?
yash is offline
Old 10-12-2006, 08:11 PM   #5 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
Exclamation Re: Repair dvds with write error, make them resusable?
Doesn't this plugin come with Nero? I think it does and replaces the one which comes by default with XP.
http://www.microsoft.com/windows/win...vice/0091.mspx
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
- by Krow
