Old 03-01-2005, 02:52 AM   #1 (permalink)
Default Deus ex invisible war
can anyone plz send me the setup.exe file from the first cd of deus ex invisible war, mine has gotten corrupted somehow.......
plz help me out.......
ghost is offline
Old 03-01-2005, 08:18 PM   #2 (permalink)
I suppose that your installation stops in between and gives an error.It is a peculiar problem with the installer that they have used and they have specifically mentioed that.The best you can do is make an image of the two disks and try to install from the image.
Do I really need a signature to be unique?
allindrome is offline
Old 04-01-2005, 12:54 AM   #3 (permalink)
well it used to work perfectly fine before, but now if i try to install the game it give the following error (this is when i double click on the setup.exe file) ---
the application has failed to start because the application configuration is incorrect. Reistalling the application may fix this problem.
... i dont understand, i have done a clean install of win xp recently so the game was'nt installed before this, so i think something is wrong with the setup.exe file only.... can anyone plssss give me this fi
ghost is offline
