| Forum |
#1 (permalink) |
Though I can receive the mails in Outlook I cant send using SMTP. Is there a problem. The software just cant connect to the server. The server settings are correct. Does anyone else has any similar problem. Pls help. I use KAV Personal Pro, Outpost Firewall also. |
#2 (permalink) |
Web Entrepreneur
yes man... fastmail don't allow u to use SMTP... means you can only get mails from there, but can't send.
use hotmail/msn or gmail.... pop/smtp are free on all of them.
Live Chat with Doctors 24x7 on my site http://healthcaremagic.com |
#4 (permalink) |
Enable the settings that says "My server requires authentication". It can be found in Tools > Accounts > Properties.
BTW, did this problem start recently only? Were you able to send messages earlier? Did you change any settings or install any new software? |
| Bookmarks |
| Display Modes | |
