Old 29-11-2006, 10:05 AM   #1 (permalink)
Default Folder Option Problem Please Help
I HAVE WINXP SP2
I had virus named rontocobol like somthing but i had removed it by mcafee antivirus but virus had removed folder option from tools menu
i want to it back without making a new user account or by group policy
how can i do this?
asif007 is offline
Old 29-11-2006, 10:33 AM   #2 (permalink)
kl_ravi's Avatar
Default Re: Folder Option Problem Please Help
Since you don't want to use Group policy (GPEDIT.MSC) you may want to try x-setup
Everything that follows is a result of what you see here...!!!
kl_ravi is offline
Old 29-11-2006, 10:41 AM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
do one thing run this Reg file... hope fully it will fix the problem...
Download
or manually edit these entries... (make sure u r a admin user...)
Start >> Run >> regedit
now navigate to
[HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Explorer]
Set or creat this value
"NoFolderOptions"=dword:0000000
[HKEY_CURRENT_USER\Software\Policies\Microsoft\Inte rnet Explorer\Restrictions]
"NoBrowserOptions"=dword:00000000
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\policies\Explorer]
Set or create this value...
"NoFolderOptions"=dword:00000000
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 29-11-2006, 03:41 PM   #4 (permalink)
well rontrokbro virus also eats the folder options and it doesnt allows to run any AV and so...
may be this reg files help
i will give a try...
be who u r :
Saharika is offline
Old 29-11-2006, 03:45 PM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
The following regcode will definitely work (which Saurav_Cheeta has already posted ):
Set value of "NoFolderOptions" to 0 or simply delete the key
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 29-11-2006, 04:48 PM   #6 (permalink)
De@d
outlaw's Avatar
thanks guys , i was facing da same prob...
Man's greatest living fear - When you die, they will find your porn"
Most people are only alive because it is illegal to
shoot them.
outlaw is offline
Old 29-11-2006, 08:50 PM   #7 (permalink)
Distinguished Member
anandk's Avatar
click http://www.kellys-korner-xp.com/xp_tweaks.htm and go to tweak number 129. download it, double click on it and add to registry. reboot.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 30-11-2006, 01:33 PM   #8 (permalink)
gg_3000's Avatar
i think that Symantec has come out with a solution to this problem and all such brontok related problems.. they are giving Fixes and .reg files that solve all brontok related problems.. I'm sorry that i dont have the links!
Google - What's that?
gg_3000 is offline
- by Krow
