hi all, i dont know why its happening with me like this.....
it all started when i installed window blinds to tweak the look of xp.....
my system is running extremely slowly and obviously i have to use task manager to hold the control of my system..... even then i couldnt able to make the tweaks in window blinds..... my system is crying to run window blinds.... i tried 2 -3 versions from different sites. result is same.....
i have a decent configuration laptop( not to blame it may be its old by anyone...) 1.83 GHz core duo p4, 2GB DDR2 RAM,256 MB ATI X1400 graphics card, 80 GB hard disk @7.2k rpm, WINDOWS XP MEDIA CENTRE EDITION & other standard configurations like bluetooth, wireless etc.
i am not able to run this window blinds pretty well in my laptop, i heard its the best at present in terms of tweaking the looks of xp i was using flyakite OSx software till now, which is also best if u wanna convert ur windows system into MAC BOOK....i just love it. and my system is pretty fast also while i am using it..... its true i have compared it....
can anyone pls guide me on how to use WB, step by step from the beginning would be preferred...... may be i am doing something wrong while installing or while configuaring it.... brief tutorial with would be better.....
i am waiting for ur response guys....
one question to vishal gupta, i am pretty sure that u r well aware of flyakite OS software, (windows to mac transformation), in that i didnt like the boot screen. because it looks like grainy or something like the colour dribbling from the oil paint.....
can u tell me vishal, how to make boot screen look perfectly clear and good looking by using simple tricks.... i wanted to use the apple silver colour screen & the blue and white mixed animated progress bar which can be seen when a mac OS is about to boot into desktop.... if i can have it in my boot screen with window blinds with ur help, i would be thankful to you....
i hope u consider my request vishal.....
