Old 27-11-2006, 08:46 PM   #1 (permalink)
Default 64 bit compatibility
Does centrino core duo T2050 ( a laptop processor) support 64 bit applications ?
vipashdigit is offline
Old 27-11-2006, 08:55 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: 64 bit compatibility
yup.. it will
the procesor supports 64bit computing what Intell calls it as EM64T
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 28-11-2006, 08:16 AM   #3 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Are you sure saurav_cheeta? I searched the net but couldnt find any evidence that it supports 64 bit.
kalpik is offline
Old 29-11-2006, 09:55 AM   #4 (permalink)
t3h g04t
teknoPhobia's Avatar
Core duo doesn't, core 2 duo does.
technologically challenged.
teknoPhobia is offline
Old 29-11-2006, 11:39 PM   #5 (permalink)
nishant_nms's Avatar
no itdoesn't only C2D for laptop support 64 bit computing
nishant_nms is offline
- by Krow
