Old 27-11-2006, 07:28 PM   #1 (permalink)
Gracias Senor
dreams's Avatar
Default Connecting 2 Computers..
Hi all..
I am out of basics now..so pls bear if this qn is very simple..
Here comes the issue..
I am havin a Laptop runnin XP SP2 and a Desktop XP SP2..
I need to access both these computers..
both the computers hv a NIC and hv connected it usin a ethernet cable..
now hw to go wit the steps..
TIA
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 27-11-2006, 07:34 PM   #2 (permalink)
Default Re: Connecting 2 Computers..
crossover ethernet cable, plus proper configuration of windows....its done!!
i can't type the whole lot in details, search around you will find step-by-step in details....no big deal.
good luck
jack// ani is offline
Old 27-11-2006, 07:49 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
go to nearest Computer Hardware store... by a 3-5m long (according to ur need, but dont streatch it to long) CAT 5 cable crossed puched with 2 RJ 45 Jack...
Now the configuration part...
Connect both PC using that cable...
Now go to Computer 1, in the network connection, Right click on the LAN Connection ICON and chose properties...
Now Set following value for the Manuall Selection of the IP address...
IP Address : 192.168.0.1
Subnet : 255.255.255.0
Getway : 192.168.0.1
Now Do the same in Computer 2, but change the IP addres,
IP Address : 192.168.0.2
Now in both PC turn on the file and printer shareing...
Next Go to My Computer of Both PC... Right Click on every Drive and click shareing and security...
Now Click Share this folder on Network and Allow others to change the Files
Click apply... now u should be able to access all files from both Computer...
P.S. Dont forget to make an exeption rule for File and Printer shareing in ur File wall or u may turn it off...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 27-11-2006, 09:08 PM   #4 (permalink)
Gracias Senor
dreams's Avatar
Thnx m8..this is awesome..kudos to all..
dreams is offline
Old 28-11-2006, 06:46 PM   #5 (permalink)
uchiha.sasuke's Avatar
hi guys ....i have a doubt regarding ethernet cable connection....Is cable is same in case of connecting a laptop with a desktop....than in a case of connecting desktop to desktop...and connection is same on side or wat??????
uchiha.sasuke is offline
Old 28-11-2006, 08:38 PM   #6 (permalink)
Rebooting
well Cable is same in every Case... its CAT 5 cable with Rj 45 Jack...
the trick is in the puching the cable in that RJ 45 Jack... There are 2 types of technique...
  1. Connecting a PC / LAPTOP with HUB / Switch (i guess its called simple punching)
  2. Connecting 2 PC / LAPTOP.. (i think its called crosssed punching)
rebooting
ChotoCheeta.com
Old 28-11-2006, 11:15 PM   #7 (permalink)
-- No Easter Eggs here --
hemant_mathur's Avatar
Is it possible to connect just 2 pc's using wifi without using an access point ?
E6850 3.0 Ghz, 4gb 667 Mhz RAM, Asus p5n Esli Mobo, Nvidia 8600GT 512mb, 400gb WD HDD, Samsung Syncmaster 920NW, Vista x64
hemant_mathur is offline
Old 28-11-2006, 11:48 PM   #8 (permalink)
Hell Sucks!!!
Yes hemant its possible.
First u need to set up a wi-fi network using ur wi-fi configuration tool(Either windows zero config or ur Company provided e.g Brodcomm) and then select the network as Ad-hoc(As between 2 comps w/o an access point) nw set this network parameters e.g security, encryption etc as u like n then go to other comp and search for network n connect to it.
Thats all nw u too r on a wireless network, nw do ur sharing as u wud do on a wired network n u can even share a internet connection nw very easily
ashu_dps is offline
Old 29-11-2006, 01:44 PM   #9 (permalink)
Thanx for the reply.
- by Krow
