26-11-2006, 11:37 PM
The No.1 Stupid
How to deal with this copy protected CD ???
Hi friends ,
I recently bought Oxford Advanced Learners Dictionary 7 and Got its CD free with it.
The dictionary is world class and Software version is even better . Now the problem is that For the software to run we need original CD in the CD ROM Drive. I mean I burnt the Image to my HDD and tried using it but it said The CD could not be authenticated . I tried burning a Copy of the CD to another CD and when i used that CD , it said original CD not found. Now , This is the first time I have encountered such a protection that I culdnt get through. I dont want to ruin my Original CD by putting it in , every time I use the dictionary , also it is not easy to pop in CD every time. So , whats That I can do to run that software without original CD , i.e. with image on HDD or copied CD.
I m using XP SP2.
waiting for ur solutions....
n00b forever...
27-11-2006, 10:22 AM
gooby pls
Re: How to deal with this copy protected CD ???
Use alcohol 120% to create image of CD and mount it.Also don't copy the cd to another because it will not work..
I am sure this will help you because i also mounted my FarCry Original Game with it...
27-11-2006, 10:53 AM
The No.1 Stupid
but why the image created and mounted by NERO7 doesnt work ??? Does Alcohol 120% do it differently????
Also , why copying the CD to another CD will not work ??? The copied CD is also autorun.
please explain.
n00b forever...
27-11-2006, 11:10 AM
gooby pls
please explain.
Use Alcohol 120 %,it is easy to create virtual images with it and when you will create then mount it with either daemon tools or with this software(Alcohol).
Copying the CD to another CD will not work because it is copy protected like games and it is illegal to copy the disk to another cd.
I never tried creating cd images with nero,just use alcohol....
27-11-2006, 11:37 AM
The No.1 Stupid
even alcohol 120% failed , oxford dictionary said "Emulator detected!
Please deactivate virtual drive and emulation software." what to do now ????
Earlier i tried ISO format( default format with NERO7) , now I tried mdf format ( default image format in alcohol 120 % ).
what to do now ??? have they really got the ultimate CD protection which even MS dont have ????
n00b forever...
27-11-2006, 11:43 AM
gooby pls
Try PowerISO and create .mdf file with it and mount it.
Hope this will help you......
27-11-2006, 12:02 PM
Nothing suggested here will work!!!
This CD is protected by CD-COPS
If you have google tool bar installed .... Just go to Toolbar options > Features > SearchBox settings > and tick Suggest popular searches ....
Now start searching for CD COPS !!!
Be advised, you may do so only if your intentions are good !!!
Other best options is to take a backup with blindwrite
I remember this thread where another person faced the same problem.
Everything that follows is a result of what you see here...!!!
27-11-2006, 12:13 PM
The No.1 Stupid
how will blindwrite help me ??
n00b forever...
27-11-2006, 12:48 PM
The Researcher
Even blindwrite will not help you. You cannot copy this as this is protected by Cd-cops. I also faced the above problem and posted my query here. If you lose your cd or make scratches on the cd, there is nothing you can do about it.
27-11-2006, 12:52 PM
Wandering in time...
Is there a minimum installation required for the software....
If yes then uninstall your current version and then install again from the image loaded in the virtual drive....
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
27-11-2006, 01:18 PM
The No.1 Stupid
@ankurgupta.me , what do u mean by min installation ????
i installed using image drive but didnt helped.
n00b forever...
27-11-2006, 01:35 PM
You'r Born Free
Dude i have only the copied cd. It runs fine on Linux.
# Money, Beauty and Configration has no ends.
# Life is like game sometimes. Play it or loose it. But keep the spirit of game.
http://en.wikipedia.org/wiki/Right_to_Information_Act
27-11-2006, 01:41 PM
The No.1 Stupid
I know it runs fine on linux. I have been using it on Ubuntu and PCLinuxOS without any problems through my copied CD. The reason is CDCOPS works only in Windows and Mac.
n00b forever...
27-11-2006, 01:57 PM
Are you sure you used fully licenced version of blindwrite ??
Demo or other versions cannot copy perfectly
27-11-2006, 02:40 PM
The No.1 Stupid
is there any way in this world to help protect my original CD from scratches by using Duplicate CD or image ????
Is CDCOPS invincible ????
n00b forever...
27-11-2006, 03:09 PM
I was under the impression that user of any genuine SW has the right to create and possess one copy of it for his own use, for archival purpose!
V.Prem Kumar
27-11-2006, 03:58 PM
The Researcher
I fully agree with you
27-11-2006, 05:20 PM
The No.1 Stupid
what about the sol. guys ????
n00b forever...
27-11-2006, 05:42 PM
#19 (permalink)
try the google toolbar method suggested by me earlier ...
27-11-2006, 05:52 PM
#20 (permalink)
@Phenom, If you are able to copy the CD contents to some directory in Ubuntu Linux.
Then use gnomebaker CD/DVD burner to burn the directory contents to
a CD!! In case you haven't installed 'gnomebaker' package.
Here is how:
$ sudo apt-get install gnomebaker
After the installation is over. start 'GnomeBaker' select the directory, right-click "Add Files".
Set the Burning Speed as "40X" Click on "Start".
That's all!!
* Imagination is more important than knowledge.
-Albert Einstein
27-11-2006, 06:17 PM
#21 (permalink)
The No.1 Stupid
@JGURU , how r u so sure that this will work???
I have GNOMEbaker Installed in ubuntu but I have already wasted a CD which I copied in windows using Ashampoo DVD burner. And why 40X ????
please tell me if u r 100% sure , only then I will try it on a CD.
n00b forever...
27-11-2006, 09:06 PM
#22 (permalink)
@Phenom, I think you must try burning the CD in Ubuntu Linux. In Windows it won't work.
Anyway, you want to take a backup of a very valuable CD. There's nothing wrong in
giving it a try in Ubuntu Linux. 40X is the speed at which you burn the CD. You can
also try burning the CD at a lower speed. The cost of a CD is just less than 10 /- Rs.
And you definitely want to take a backup of the CD right? Then go ahead.
-Albert Einstein
27-11-2006, 10:40 PM
#23 (permalink)
Super Hero - Super Powers
@ ~Phenom~
If u don't want to waste a CD then just use a ReWritable CD. If u succeed then u can burn on a Recordable CD.
Minds are like Parachutes :arrow: They work best when open
27-11-2006, 11:26 PM
#24 (permalink)
The No.1 Stupid
should i first copy the contents to a folder and then burn it to a CD or should i directly copy the CD????
n00b forever...
27-11-2006, 11:35 PM
#25 (permalink)
Better to copy the contents to ur Hard Drive first.
28-11-2006, 01:13 AM
#26 (permalink)
The No.1 Stupid
arrgh!!! I copied the contents to a directory and then tried burning the contents with GNOMEBAKER but burning failed saying some UTF-8 Error something.
I m feeling screwed up , another CD wasted. To hell with the OALD7 , I aint gonna use/try it any more.
n00b forever...
Search this Thread |
LinkBack to this Thread: http://www.thinkdigit.com/forum/qna-read-only/42226-how-deal-copy-protected-cd.html
| Posted By |
For |
Type |
Date |
| Untitled document |
This thread |
Refback |
03-02-2011 03:43 AM |
