I am using the AMD athlo XP 2000 and mercury mother board and 512mb ram, i am trying to overclocking the processor from the BIOS options, i changed clock speed to 166MHz from the 133MHz.After save it & booting again the machine not yet to boot, monitor blinks again.How i will boot the machine.
You crazy or what !! You increased the FSB by 33Mhz in one go !!!!!!!!!!
Thats sheer foolishness ! You processor might get fried ...that is if the PC boots in the first place. Decrease the FSB to 133Mhz and then start up again. There is a sticky in hardware on overclocking AMD processors, plz refer to that.
reset ur BIOS to default by using Jumper or remove battery and wait till 5 to 30 minutes depending on ur mobo, let the BIOS set to defaults ie 100MHz, then boot and set it to 133MHz
1 aadi + 1 aadi = 1 full ;)
