Old 02-01-2005, 02:24 AM   #1 (permalink)
Default can't access net when firewall is on
i have been trying to access net when i use zone alarm pro. but there is some problem in my system that does not allows me to connect to any site what soever. i switched to sygate personal firewall pro today to check whether it is the issue with zone alarm, but the problem persists.
i can connect to net effortlessly when i switch the firewall off.
can you guys help me out here, coz i firmly beleive that there is some havoc being played in my system. i have norton system works 2004 installed on a p4 3.0 ghz, 256 mb ddr ram, win xp sp2, 80+40gb hdd, intel 865 original board
arizhasan is offline
Old 02-01-2005, 08:02 AM   #2 (permalink)
hi,
What is the firewall u r using before zonealarm and sygate. Have u completely uninstalled it.
elumalai is offline
Old 02-01-2005, 01:02 PM   #3 (permalink)
Ethan_Hunt's Avatar
Seems That Ur Firewall Is Blocking a Port 80 Which is required For Surfing The Net....Just Customise Ur Current Firewall To Open Up That Port And Then Try It Out......
Ethan_Hunt is offline
- by tv6952
