It relates to Windows XP Home Edition. Usually, the Desktop screen is horizontally on monitor screen. But it has become vertically facing bottom when I placed my book on the keyboard unfortunately during my operation. How to correct it? Your immediate reply will be appreciated.
i don't exactly know the solution but then try doing it with control buttons on the bottom of ur monitors..it differs from moinitors but you'll have to keep on trying till you get the answer
Some keyboard shortcut is the cause for this change in orientation.. It is CONTROL + SHIFT + ARROW KEY... Try this combination using any of the 4 arrow keys.. It'll be back alright..!!
