Old 25-11-2006, 10:11 PM   #1 (permalink)
Post is it possible ????
I’m back with my 2 new Q’s & my following Q’s are as follows ->
1st question: Is it possible during the installation of windows xp pro, that we can make only 1 administrator account (made by the software itself). During last time when I installed my windows. I make my 3 accounts namely: “administrator (made by the software), techno_freak87(both administrator accounts )” & “1 user account”.
I have to make 2 more accounts last time becoz the software was not allowing me to leave the user name space empty. But, at this time I want only to make 1 account during the installation of the widows but I can’t find any way to do it. Can u help me up?
2nd question: I’m not being able to delete my temporary files from “c:\windows\temp”.
how can I delete them?
sandeep bhatia is offline
Old 25-11-2006, 10:52 PM   #2 (permalink)
kirtan's Avatar
Default Re: is it possible ????
Well my answer sheet for the question paper is
1.A.Well u have to make one administrator account and atleast one user account during the installation of xp-pro.I don't think there is another way out.But u can make the changes to these accounts in windows.Go to Start->Run->type control userpasswords2.U will be given the options and alter them accordingly.
2.A.U can use any third party sw like system mechanic or ccleanerhttp://ccleaner.com
Water can flow or it can crash.Be Water my friend.
kirtan is offline
Old 25-11-2006, 11:16 PM   #3 (permalink)
overclocker's Avatar
Otherwise u may use empty temp folder for cleaning temporary files.
Download Link: http://www.danish-shareware.dk/soft/...temp2Setup.exe
overclocker is offline
Old 26-11-2006, 12:03 AM   #4 (permalink)
Distinguished Member
anandk's Avatar
go into safe mode and del ur temp
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 27-11-2006, 08:37 PM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
1.) Yes! It can be done. Its called "Unattended Installation".
Just create winnt.sif file into I386 folder and copy following code into the file:
[GuiUnattended]
AutoLogon = "Yes"
EncryptedAdminPassword = "No"
AdminPassword = *
OEMSkipRegional = 1
OemSkipWelcome = 1
Or U can use nLite for it!
2.) Use unlocker and delete the file
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
- by Krow
