I am trying to create an image file from the Longhorn beta Release cd,using the nero, it flying thro' 50% then the following statement generated by nero "Unrecoverable read error at some location <...> on disk".But i was installed the OS by using the same CD and also i am try using another drives like sony, samsung but yet not get image.
Just try copying the cd to a temporary folder on your hard disk using windows explorer. If there is any physical damage to the cd, then at some point, the copying will fail and u can tell which file(s) are damaged. Its possible that while installing from the media, these files are not accessed.
Maybe to CD is protected ..You can try to create its image and run it ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
use blindwrite to make exact copies
or even clonecd
i hear good things abt alcohol too
anyways with these softwares .. amek sure u dont burn on the fly
make an image first
No Mercy, No Limits.
