Old 25-11-2006, 01:43 PM   #1 (permalink)
Default Pls Help
Hello friends,recently I bought a laptop from my friend.Iam going to use this laptop for presentation, music, browsing and to store files. The following s/w are there in my lappy 1) j2SE runtime environment 5.0 update 6 (119.00MB)2) java 2 runtime environment, SE v1.4.2_03 (136.00MB)3)lernout & Hauspie truvoice American TTs engine Do I need this s/w to run my system? What is the use of these s/w?
techdevil is offline
Old 25-11-2006, 01:52 PM   #2 (permalink)
An Esoteric Geek
sridatta's Avatar
Default Re: Pls Help
J2SE runtime environment is for programs built in JAVA. TTS engine means Text To Speech engine.. You do not need these softwares for any of your applications listed.
sridatta is offline
Old 25-11-2006, 01:57 PM   #3 (permalink)
The Researcher
java runtime environment is required for browsing. If it is not installed, you may not be able to to enjoy many sites that uses javascripts.
Ramakrishnan is offline
Old 25-11-2006, 02:36 PM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
you may uninsall all those software... JAVA sofwtare u maintioned is for development purpose... therefore ur need, u pay uninstall and delete all those 3 software...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 25-11-2006, 07:52 PM   #5 (permalink)
nishant_nms's Avatar
I will suggest u to keep java
nishant_nms is offline
