Re: photo
usually, as far as size of the file is concerned, jpeg gives the most choice (among the common formats) Just try exporting to jpeg aaat 80% quallity. Also most photos from cameras are too big in canvas size. Just try scaling it down to 50% by 50%. You will see a big difference in size. Make sure to keep the original as any editing done to the jpeg file will further reduce the quality. I recommend irfan view for such conversions. It is simple and has a slew of options.
Life is too short. Have fun.
