Old 24-11-2006, 08:41 PM   #1 (permalink)
Let the music play.....
djmykey's Avatar
Default dumprep ??
Hi all,
I just ran msconfig from my run dialog box and it gave me the msconfig. In the startup tab there is an entry called Kernel fault and its command is
%systemroot%\system32\dumprep 0 -k
What is this?? And is this really needed?? Replies will be appreciated.
Thanks in advance.
djmykey is offline
Old 24-11-2006, 09:08 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: dumprep ??
This comes after an improper shutdown, dumps the memory into a file, not needed if your PC's working fine.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 24-11-2006, 09:48 PM   #3 (permalink)
why need title?
bharathbala2003's Avatar
more info
The Dumprep.exe tool is a Windows XP fault logging program. If a serious error occurs, Dumprep.exe writes the error details to a text file. The Dumprep.exe tool then prompts you to send the error information to Microsoft. The Dumprep.exe tool is a non-essential system process that is installed for third-party use.
bharathbala2003 is offline
Old 24-11-2006, 10:28 PM   #4 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Don't worry! U can safely remove it from the startup list
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 24-11-2006, 11:30 PM   #5 (permalink)
De@d
outlaw's Avatar
when some of my app's freeze and i try to close them via task manager this "dumprep"thing appears on the taskmanager and i've found that ending dumprep will kill the "non responding" application instantly
Man's greatest living fear - When you die, they will find your porn"
Most people are only alive because it is illegal to
shoot them.
outlaw is offline
