Old 06-08-2004, 03:27 AM   #1 (permalink)
Posts: n/a
Default Restarts the Pc!.....
When i turn of the Monitor and against tur on with in sec/min my pc will automatically restarts.Why and what will happen,I am using the BPC .5Kva UPS and 15" monitor.
Old 06-08-2004, 02:15 PM   #2 (permalink)
It could be because of the initial surge of voltage required to power your monitor - that your ups is unable to provide. Try connecting the monitor directly to the mains. Nowcheck and see if it happens again
sailendra is offline
Old 06-08-2004, 08:44 PM   #3 (permalink)
mariner's Avatar
check ur ram modules.might be loose.
mariner is offline
Old 07-08-2004, 08:20 AM   #4 (permalink)
aadipa's Avatar
its due to UPS
i get same problem with Microtek 600 VA UPS
i cannot start my monitor when running on UPS battory without restarting pc, but when mains are on, there is no problem.
btw why turn off monitor, use power saving modes.
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 07-08-2004, 03:26 PM   #5 (permalink)
well...i had seen that in a Digit issue a couple of months back(dont remember which one) in the Q & A section.someone had the same problem and Digit said to get the power supply checked at a service centre since it was faulty.i think your problem also lies in the power supply.check out that issue.
asky is offline
Old 11-08-2004, 10:41 PM   #6 (permalink)
Hmmmmmmm....
consult a pc doctor immadiately !!
or may b ur pc supplier from whom u bought ur pc !!
cosx is offline
Old 12-08-2004, 12:36 AM   #7 (permalink)
lavan_joy's Avatar
hey ptd_infotech tell ur config.
Do u use any large screen moitor?
LAZINESS IS THE ENEMEY OF SUCCESS
lavan_joy is offline
Old 12-08-2004, 01:11 AM   #8 (permalink)
several possibilities to ur problem
-->one may be monitor has become faulty
--> prob is caused by faulty ups
--> smps is not supplying enough power
--> or it mght be soemthing not to do witb ur monitor itself
My suggestion if comp is under warranty immediately contact vendor/dealor of ur pc
else get professional help from a pc doctor surely ur vendor will be more than obliging to help u
also if he says theer is a problem get it verifed by discussing it here
and then opt fore the solution or u mght be taken for a costly trip
Attack life, it\'s going to kill you anyway.
walking-techie is offline
