Old 23-11-2006, 12:21 AM   #1 (permalink)
fff..fire fire...
Binay 007's Avatar
Exclamation Actual defination
I got an defination of host in networking is that A server having all the domain name.
wht its actual meaning can anybody make me understand.
thax in advanced
Binay 007 is offline
Old 23-11-2006, 12:30 AM   #2 (permalink)
SE><IE
Posts: n/a
Default Re: Actual defination
well, a host is a computer connected to a network. Like in LAN, you can call the connected PCs as hosts. Although you can use words like computer-1 etc but host is a standard word and has the same meaning.
No, a host may not me in a domain.
Just like you say node in graphs, the same way you say host in networking.
Hope this made it clear for you.
Old 23-11-2006, 09:54 AM   #3 (permalink)
overclocker's Avatar
The system that contains the data is called the host, while the computer at which the user sits is called the remote terminal. A computer that is connected to a TCP/IP network, including the Internet. Each host has a unique IP address.
"Hosts" may refer to the hosts file, a file that serves to look up Internet Protocol addresses.
overclocker is offline
