Originally Posted by techno_funky
ok well from what i got u mean that
when the visitor puts in the domain name the nuke site should open
i.e www.xxx.xx will open the nuke site
ok to do tht u will have to install nuke directly in your webspace
without creating any folders
you will have to install it the "www" folder
make no folder in this folder directly install it in this "www" folder
Well Thats Fine ! But still
www and
public_html are the same. And this is only for Linux Servers. For IIS and Windows 2003 Servers, you have to install under
wwwroot dir or
inetpub according to the host you choose.
Anyways, please do post such queries under "
QnA" section, so tht many ppl can answer these stuffs.
And mention which OS you wanna install php nuke under. And as always read the "intsall.txt" or "readme.txt" file, tht comes along with php nuke pacakage for better inforamtion.
Vinay
