Old 21-11-2006, 10:27 PM   #1 (permalink)
manishjha18's Avatar
Question help required
1-help and support tab not responding
2-find target tab not responding
3-ie 7 not working-
4-only right click working in windows media player 11
windows xp pro with sp2
manishjha18 is offline
Old 21-11-2006, 11:28 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: help required
Well seems that ur xp has gone mad.Use any two gud updated antispyware and one gud updated antivirus...n do full scan of ur computer.If possible do online scan at www.bitdefender.com ...if problem continues repair ur xp.
ravi_9793 is offline
Old 21-11-2006, 11:35 PM   #3 (permalink)
Still Shining!
Lucky_star's Avatar
Reinstall XP!!
Nokia N86 8MP
Lucky_star is offline
Old 21-11-2006, 11:36 PM   #4 (permalink)
GeekyBoy's Avatar
This can be a virus. Log on into safe mode and run a virus scan with your antivirus- remove the ones which are infected.Run a spyware scan with Spybot and remove the spyware. Install all the security updates.
Intel Core i3 2100 //4GB Corsair DDR3 1333 RAM //Intel DH61WW//Sony AD-7260S DVD-RW//Samsung 2033SW Monitor//Windows 7//Seagate ST3250310AS 250GB HDD
GeekyBoy is offline
Old 22-11-2006, 12:03 AM   #5 (permalink)
overclocker's Avatar
Do u change any settings with the help of resource hacker. Bcz few days ago I change my start button name through reshack so this time the 1st nd 2nd prb was occured.
overclocker is offline
Old 22-11-2006, 02:56 AM   #6 (permalink)
buddy-using bitdefender v 10 -
i dont want to format--its my last resort
one more recent error i am getting---
svchost.exe-application error
the exception unknownsoftware exception(0xc0000409) occured in the application at location 0x5b86a3c0
Old 22-11-2006, 03:09 AM   #7 (permalink)
Beneath The Eyelids
The Outsider's Avatar
run the memory test, try another ram.
The Outsider is offline
Old 22-11-2006, 06:41 AM   #8 (permalink)
1. Run services.msc and check if Help and Support Services is started. If not, right-click on it and select Start.
2. What is the Find Target Tab? In which application? Do you get an error? What is the error message?
3. Do you get an error when you try to open IE7? What is the error message? Did it work earlier?
4. No clue regarding wmp11...
Try the following: 1. Run CCleaner and clean your registry. 2. Enter safe mode and run antivirus, antispyware and sfc checks. 3. Defragment your harddisk.
Arun
sakumar79 is offline
Old 22-11-2006, 07:19 AM   #9 (permalink)
Kiran.dks's Avatar
Whatz ur system configuration?
Kiran Kumar R
Kiran.dks is offline
Old 22-11-2006, 05:13 PM   #10 (permalink)
Distinguished Member
anandk's Avatar
make sure ur help and support services is set on automatic and started.
download from kellys-korner this script, which repairs 'Windows Help and Support.
which find tab ? or do u mean the search tab !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 22-11-2006, 05:31 PM   #11 (permalink)
I hope ur virus definitions are updated,buddy.Switch to safe mode,run a thorough virus scan & also a spyware scan.
harpoon is offline
Old 22-11-2006, 10:18 PM   #12 (permalink)
amd 3500-
ram 512 mb,nvidia 6600gt 256 mb graphics card-
help and support service is enabled-
on every shortcut ,when i right click and then go to find target tab -it doesnt respond even after repeated clicking on find target tab.
i ie earlier it used to work but now i dont get status bar and on address bar if i go to any site -it says that the site is currently unavailable--
Old 12-12-2006, 09:22 AM   #13 (permalink)
Question Re: help required
I am having this exact same problem. IE7 will open, but not display a status bar, won't connect to homepage, if you type in an address it says it's currently unavailble. The option drop downs in the upper right corner appear, but won't open anything. Only way to close the browser is to end the process in task manager.
My PC is setup with two accounts. IE7 works in one but not the other. I've tried re-installing IE7 but it didn't help. FireFox works fine in both accounts.
I've run RegClean. AntiVir Guard finds nothing. Microsoft Malicious Removal Tool finds nothing. ZoneAlarm finds nothing. I tried System Restore to a check point 3 days old, but it said nothing had changed.
I also tried to create a new account, and IE7 is goofy under that account too.
Bizarre!
seagoon is offline
Old 12-12-2006, 11:42 AM   #14 (permalink)
First Reinstalled Office Xp,restart Ur System ,
If It Is Still Not Working , Then Reinstall Xp
suraj is offline
