Old 21-11-2006, 01:31 PM   #1 (permalink)
The Devil's Advocate
iMav's Avatar
Default annoying popups on login
guys i hv sify bb conx whenever i log in there are 2 separate windows opened by it for promotional purposes plz tell wat registry entry to edit to disable it
http://beingmanan.com
iMav is offline
Old 21-11-2006, 03:12 PM   #2 (permalink)
kl_ravi's Avatar
Default Re: annoying popups on login
Try adding sify.com to list of restricted sites ... This way pop-ups will be blocked ...
Incase you are using Sify dialer, don't use it instead use the IE dialup connections ...
Everything that follows is a result of what you see here...!!!
kl_ravi is offline
Old 21-11-2006, 03:36 PM   #3 (permalink)
iMav's Avatar
they are not pop-ups so to say they are more like windows tht open for any dialer .... for example if u connect thru tata also ur default browser opens with a page sify opens 2 such windows (over-rides the tab browsing thing in IE) and as sify is set to auto connect on startup these windows slow my machine
iMav is offline
Old 21-11-2006, 05:30 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
Try to use any gud pop blocker.I wish it may solve ur problem
ravi_9793 is offline
Old 22-11-2006, 01:30 AM   #5 (permalink)
iMav's Avatar
popup blockers do not solve this problem..... vishal the rsgistry guru plz tell me which reg entry to change
iMav is offline
Old 22-11-2006, 01:39 AM   #6 (permalink)
SE><IE
Posts: n/a
type secpol.msc at run dialog box.
Now goto Software restriction policy , right click and select new policy.
Now goto Software restriction policy > Additional rules. Right click in the right hand pane and select new path rule. Enter the path to BBImpSec.exe (in %programfiles%\Sify Broadband) and select Disallowed as security level from the drop down menu.
click OK.
Create a new path rule and point to BB_CustomMessage.exe (in %programfiles%\Sify Broadband) and select Disallowed as security level from the drop down menu.
click OK.
You won't ever be bothered by the annoying pop-ups
