Re: digcam
no they do not, and in theory, u can never achive perfect deletion, but for any storage type, for instance magnetic, if u overwrite the data 3-4 times, then it is as good as gone, and all softwares use the same technique, so basically there is no need to buy one, just use the dm command in linux, and u are good to go, or if it's an entire device, u know what to do.
