View Poll Results: better perfomance
amd 2 40.00%
intel 3 60.00%
Voters: 5. You may not vote on this poll
Old 05-08-2004, 10:37 PM   #1 (permalink)
Default right combination
hi
which is better to buy amd or intel .amd gets hot but its 64 bit and intel is
32 bit .i wanna use the sys for multimedia which one would be better
i was thinking of intel p4 with intel 925 mobo everyone said that amd is 64 bit.if amd which one amd athlon,fx or xp series
so help me get out of this right combination of cpu and mobo.
pls help me bcase i upgrade system once in 3 1\2 yrs so some good suggestion
and more posts
arun is offline
Old 05-08-2004, 11:00 PM   #2 (permalink)
Default Re: right combination
Originally Posted by arun
hi
and more posts
AMD 64 is deinitely a better buy if u are looking for future compatibility and good performance. AMD 64 proccys dont get hot, infact they are the coolest processors available around.
The AMD FX series is their flagship series, which is very costly. The vanilla AMD 64 proccy has all the right stuff for the normal user. For the motherboard go for Asus K8V or Gigabyte K8T800M. There is one from ASROCK too but it's not that good.
www.techenclave.com Ecumenical Technology !:)
blade_runner is offline
Old 05-08-2004, 11:02 PM   #3 (permalink)
NikhilVerma's Avatar
I like intel...
NikhilVerma is offline
Old 06-08-2004, 01:16 AM   #4 (permalink)
aadipa's Avatar
AMD 64
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 06-08-2004, 02:21 PM   #5 (permalink)
what ur budget?
akshayt is offline
Old 06-08-2004, 04:52 PM   #6 (permalink)
for multimedia and games go 4 amd 64 fx
PIII 550 MHz 128 MB RAM GeForce 2 MX 400
.:pEaCe:.
Join this cool forum!
www.tech-station.net
Loki87 is offline
Old 06-08-2004, 10:24 PM   #7 (permalink)
Default re;
whts the price of amd 64 fx i am looking for something around 15k.and mobo around 10k
arun is offline
Old 06-08-2004, 11:45 PM   #8 (permalink)
gxsaurav
Posts: n/a
Intel upto 3.06 or 3 Ghz with northwood core, no prescott, above that AMD 64 with 939 pin. My Hign end config will be AMD 64
Old 07-08-2004, 08:38 AM   #9 (permalink)
aadipa's Avatar
AMD 64 FX is much costly, may be more than 30K
u can go for plain AMD 64
aadipa is offline
Old 07-08-2004, 10:46 AM   #10 (permalink)
Latest fresh prices for AMD 64 at lamington
AMD 64 2800+ 7.1k
AMD 64 3200+ 11k
