Old 31-12-2004, 12:39 AM   #1 (permalink)
Default pc too slow
i have got a 2.4 pentium 4 845 chipset with win xp pro running in it i have 128 mb ram my pc works like a snail what should i do to make it run faster
shikhar_kapoor143 is offline
Old 31-12-2004, 12:57 AM   #2 (permalink)
swatkat's Avatar
There may be several reasons.Follow these steps.
1]Run ScanDisk.
2]Defragment the Drives.
3]Clean Temp files/Waste files using softwares like GLock Temp Cleaner or UltraWipe.
4]Clean Registry using softwares like RegCleaner or RegSupreme or System Mechanic.
5]Close the unused/less used services/processes running in background.
6]Since u have 'less' RAM,increase Virtual Memory/Page File Size.
7]If u are using XP switch to Classic View and disable some of the special effects (Right Click My Computer go to Properties,there go to Advanced tab to make changes.)
8]Scan for Viruses/Trojans using any updated AV.
http://swatrant.blogspot.com/
swatkat is offline
Old 31-12-2004, 02:18 AM   #3 (permalink)
sms_solver's Avatar
If you have time, back up yr essential data to CD
and format and reinstall XP
and then install all latest updates
sometime hardway like this produces good result
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
