Old 17-11-2006, 11:28 PM   #1 (permalink)
Anindya's Avatar
Question Suggest a project.
Can anyone suggest me a project which can be done on C. U can also suggest one on Visual FoxPro.
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
Anindya is offline
Old 18-11-2006, 01:22 AM   #2 (permalink)
String Phreak
mediator's Avatar
Default Re: Suggest a project.
Enhancing images,decreasing the file size with lossy compression. Wat say??
mediator is offline
Old 18-11-2006, 09:19 AM   #3 (permalink)
aniishvara@gmail.com's Avatar
it all depends on whether u r a beginner in C or have a good programming knowledge of the data structures etc in C...
well if u a beginner.. then i suggest u do some projects like making some games aka KBC ones etc which help u learn about graphics in C
or if u have some good programming experiance in C then theres a lot that i can tell u...
!> if u know abt API's then make some good text editors using them
{do make use of mouse pointers not just arriow keys of keyboard }
@> how about making a program which searches the whole of your disks for specific files etc
or u cud also do some kinda database stuff as well
the options are endless....it only depends on the quality time that u can spend on the project ...
Laugh and the world laughs with you, Snore and you sleep alone..
aniishvara@gmail.com is offline
Old 18-11-2006, 11:17 PM   #4 (permalink)
Anindya's Avatar
Exclamation Re: Suggest a project.
Yes I am a beginner. But I need to submit a project at the end of the semister.
To Mediator Ur option is too tough for me. Please suggest a easy one.
To aniishvara I will think about the HDD search idea.
To all Pleasl give me some more option. Either on C or on VFPRO.
www.techani.com
Anindya is offline
