Old 30-12-2004, 02:24 AM   #1 (permalink)
gsmsikar's Avatar
Default recording to the PC?
hi
please help me ,
i want to record live video shooting to my PC using a video camera which have a audio/video output ..
i have seen a Techcom tv tuner cards which is available in the market at a range from rs 1300 onwards.. but didnt get a satisfactory result..
should i go for a tv tuner card or is there any card which can only accept Audio/Video in ?
or is there any USB cable or converter for AV in ?
my system is
P3 800Mhz
128MB ram
80GB 7200 HDD
LG CD Writer.
thanks
please help me..
gsmsikar is offline
Old 30-12-2004, 02:33 AM   #2 (permalink)
Default use windows movie maker
mate, if u have windows xp sp2(its movie maker is absolutely superb), you should just download the driver for your cam on the comp(either with the cd or from net). Then simply connect your camera via usb to your comp and let windows install it. After that its simple to record both audio and video by running windows movie maker.
docbat is offline
