Old 16-11-2006, 07:38 AM   #1 (permalink)
Wink how to compress a scanned photo
hi guys i got my school group photo scanned and i saved on my hdd but its whopping 7 mb n resolution is 3514x 2567x24b can i compress it without affecting its clarity?THANKS
EVERYBODY WANTS TO GO TO HEAVEN BUT NOBODY WANTS TO DIE
mandar5 is offline
Old 16-11-2006, 08:06 AM   #2 (permalink)
Kiran.dks's Avatar
Default Re: how to compress a scanned photo
You can do that to various sizes depending upon your requirements.
Download Freeware: PIXresizer
Alternatively you could download WindowsXP Powertoys( for Windows Genuine Users).....
Image Resizer Power toy
This power toy integrates with system default right click menu. Just click photo and right-click to resize!
Kiran Kumar R
Kiran.dks is offline
Old 16-11-2006, 08:52 AM   #3 (permalink)
thanks yaar kiran but will it affect photo quality
mandar5 is offline
Old 16-11-2006, 09:26 AM   #4 (permalink)
Kiran.dks's Avatar
Welcome
It depends upon how much resize you are doing. If you choose too small file size, then obviously you will get pixlated image when you zoom. For normal viewing and 6"x4" size photo prints, resize images to 1632x1224 size. Bigger the prints required>Larger the size.
Kiran Kumar R
Old 16-11-2006, 11:02 AM   #5 (permalink)
Come get Some
DukeNukem's Avatar
use acdsee for conversion
jus convert it to JPG at 100%
or use Photoshop
simple
with virtually no chopped quality.
Computers are like Air Conditoners, thet stop working properly when u open WINDOWS.
DukeNukem is offline
Old 16-11-2006, 05:13 PM   #6 (permalink)
JGuru's Avatar
If you want lossless Image quality then save the file in PNG format. If you need to
print the Image then save it in TIFF format. Remember JPEG is lossy. So better use
PNG or TIFF format.
* Imagination is more important than knowledge.
-Albert Einstein
JGuru is offline
Old 16-11-2006, 07:35 PM   #7 (permalink)
Thanks yaar kiran u r simply awesome great advice.
Thanks a lot guys.
mandar5 is offline
Old 16-11-2006, 07:50 PM   #8 (permalink)
Kiran.dks's Avatar
Welcome!
Kiran Kumar R
