Old 29-12-2004, 09:44 PM   #1 (permalink)
Default suggest me a computer under 30K
please suggest me a computer under 30K.
give its configuration toooooo
mylifevp is offline
Old 29-12-2004, 10:17 PM   #2 (permalink)
the configuration of the computer will depend entirely on your requirements and preferences .Mention them specifically.
bhare ka tattoo is offline
Old 30-12-2004, 01:01 AM   #3 (permalink)
SABER RIDER
maverickrohan's Avatar
Here's The Best Config, acc to me(For ur Budget which is too low)-------->>>>>>>>>>
AMD Athlon64 2800+
Rs.6250
Asus K8V-SE Deluxe(VIA Chipset)
Rs.6000
Hynix 512MB DDR SDRAM(400MHz)
Rs.3400
LG Flatron/Samsung Magic Bright 17"
Rs.8000
Seagate Baracudda 80GB (7200rpm)
Rs.2800
GeForce4 MX 440 (8x 128MB DDR)
Rs.2500
Samsung DVD/CD-RW Combo
Rs.2600
iKey Keyboard & iBall Opti Mouse
Rs. 600+Rs.600
350W ATX Cabinet
Rs. 1200
Altec Lansing 2.1 Speakers
Rs. 1300
TOTAL = Rs. 35,250
Well, I know this exeeds ur buget a little, but if u wanna buy a comp in this era, buying anything inferior to that would be injustice
I have suggested a DX8 GFX, thats cos of ur low budget, but after a year or so u can easily upgrade it!!!
To Reduce the cost u can go in for an AthlonXP 2800+ & a nForce2 Mobo!!!
But i wud not suggest that, it will make upgrading more costly in the long run........
!!!ENJOY!!!
Find out Which is The Best Video Codec?....And how to encode video the right way..!!----->>>>> http://www.thinkdigit.com/forum/showthread.php?t=3908
maverickrohan is offline
Old 30-12-2004, 02:52 AM   #4 (permalink)
Have a look at my post on Dec 24 under the thread "Buying a New PC - Need pricing" (my second post, not the first one on Dec 23). My suggestion there will give you better performance, esp in gaming, than a low-end 64-bit system for the same price.
The total is 31.6k. If you must stay within 30k, you can reduce the amount of RAM to 256MB and save about 2k. OR you can retain the 512MB RAM and save 6k by omitting the separate gfx card and use the onboard graphics for the time being. You can always add a better card later.
The onboard graphics is a GeForce4 MX (upto 128MB). You'll be able to play most games at low to medium settings. The exceptions are those that require a card with T&L capability, like Splinter Cell.
pimpom is offline
Old 30-12-2004, 11:03 PM   #5 (permalink)
I would like to add to what maverick has suggested, a sony floppy drive for Rs. 350, also I think you could get the Samsung 17" Syncmaster753s for around Rs.6,200. Not to forget you can get a very cool IBM Optical mouse for as little as Rs. 350 and an Acer Keyboard for Rs. 350 as well.
So Rs. 35,250
(-) 8,000 ---Monitor --Maverick's Suggestion
(-) 1,200 --- Keyboard and Mouse -- Mavericks Suggestion
(+) 6,200 --- Monitor I Suggested
(+) 700 --- Keybrd and Mouse suggested by me
(+) 350 --- Floppy Drive
_______
33,300
________
Not much of a saving but something is better than nothing. If you want it cheaper - you will have to compromise on the processor and Ram, I think 256Mb should be enough to start with, also a Celeron would be cheaper than an AMD64.
Let us know what you have decided
Best of Luck.!
EDIT: - If I were to upgrade/buy a new PC now, I would wait some more time, save money and get a PCI-E set-up.
Major-Minor is offline
