Old 14-11-2006, 03:23 PM   #1 (permalink)
Pragadheesh's Avatar
Unhappy Serious Error...!!!
hi, at times wen i start my system , i get this error
"Microsoft Windows
The system has recovered from a serious error
When i click 'For More Details click here' i get this:
Error signature:
BCCode : c2 BCP1 : 00000041 BCP2 : 85BB2000 BCP3 : 000057B2
BCP4 : 0001EF2E OSVer : 5_1_2600 SP : 2_0 Product : 256_1
The following files 'll be included in this error report:
C:\DOCUME~1\PIKKI\LOCALS~1\Temp\WERfca6.dir00\Mini 110406-01.dmp
C:\DOCUME~1\PIKKI\LOCALS~1\Temp\WERfca6.dir00\sysd ata.xml"
This error doesnot occur every time.. plz explain me wats wrong n y this error occurs???
Pragadheesh is offline
Old 14-11-2006, 04:14 PM   #2 (permalink)
Kiran.dks's Avatar
Default Re: Serious Error...!!!
This is a known Windows vulnerability.
This message shows a problem with mini dump or memory dump. It happens when Windows creates a memory dump file and ignores it. When it again attempts to create the file, there results a conflict. This leads to a serious error message.
Solution:
Download: KB317277 Update
Restart system after installing the update.
This should solve your problem.
Kiran Kumar R
Kiran.dks is offline
Old 14-11-2006, 04:28 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
hmm...could be that ur driver for the video adapter is of the incorrect version.
check here http://support.microsoft.com/?kbid=318023
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 17-11-2006, 04:05 AM   #4 (permalink)
Post Re: Serious Error...!!!
1) thanx kiran n anandk , but d download file whice Kiran.rkk gave (KB317277) is for XP SP1 instead 'm using XP SP2.. can u get me plz d appropriate download file??
2) i tried NFS carbon om ma sys (P4 2.8 Ghz , Mobo-D865GBF,RAM-512Mb,Inbuilt 64 MB video memory) but it didnt work.. got installed successfully but wen i launched d game , i got this error - "NFS carbon has encountered a problem & needs to close, we r sorry for d inconvenience". But wen i clicked more details in d error dialog box , i got d same "ERROR SIGNATURE" which i mentioned above..
Why is this problem ?? Does ma pc support d game or not ????I desperate to play Carbon frenz..
plz help me in sorting out this problem..
Old 17-11-2006, 08:31 AM   #5 (permalink)
Still Shining!
Lucky_star's Avatar
You have to buy a Graphic Card to solve the problem.
Onboard Graphics is not enough to play those games. NFS Carbon and other some other games do a hardware check before starting up. And if your hardware configuraion is not according to the games requirements then an error similar to yours pops up.
Only 512 MB memory or onboard 64MB video card is not enough. Upgrade.!!
Nokia N86 8MP
Lucky_star is offline
