Old 14-11-2006, 07:48 AM   #1 (permalink)
Default RAM problem..?
I am from Dehradun(Uttaranchal).I am looking for a 512 MB RAM 266 MHz.So I asked my dealer he said that 512MB RAM at 333Mhz is available .I tried a 333 MHz RAM on my PC but it haven't worked bcoz my motherboard supports only upto 266 Mhz of RAM.I searched nearly all computers stores in my city but haven't find one.Please tell me are 266 MHz RAM's obsolete or if they are available where can i find one..?.
Also tell me that instead of buying a new RAM should i go for a motherboard upgrade...?
vineetrocks2005 is offline
Old 14-11-2006, 09:13 AM   #2 (permalink)
Default Re: RAM problem..?
I have also 266MHz supporting mobo(D845GBV). but i am using Twinmos 256MB 400MHz ram without any problem.
bhoolkumehul is offline
Old 14-11-2006, 10:00 AM   #3 (permalink)
Wandering in the zone ...
manas's Avatar
My motherboard too supports 266MHz modules.But my new Hynix 512MB RAM module 400MHz works perfectly.
The new Hynix memory modules automatically decrease the frequency to the one that the motherboard supports.So you should have no problems.
Not all those who wander are lost. :D
http://www.manast.com ---- ManasT
manas is offline
Old 14-11-2006, 11:04 AM   #4 (permalink)
i want a RAM module that can work with my existing 128MB 266 Mhz module
Old 14-11-2006, 11:32 AM   #5 (permalink)
manas's Avatar
No problem, any Hynix 400MHz memory module will be compatible with your existing module.
manas is offline
Old 14-11-2006, 11:34 AM   #6 (permalink)
can u tell how much a Hynix 512 MB 400 MHz module will cost..?
Old 14-11-2006, 12:16 PM   #7 (permalink)
manas's Avatar
Hmm, i had brought one 3 months ago for Rs 2300/-...
manas is offline
Old 15-11-2006, 07:18 AM   #8 (permalink)
hey can u tell me from where i can get this RAM in India.Is it easily available
Old 15-11-2006, 09:26 AM   #9 (permalink)
manas's Avatar
ya, in very decent computer hardware shop..
Ask for Zion RAM module with Hynix chipset...
manas is offline
