Old 29-12-2004, 04:45 PM   #1 (permalink)
Default Tweak & Code needed urgently
Hello
I need a Tweak to make windows accept a file length of more than 20 characters unlike the default.
For eg Windows will allow u to name only a file upto certain characters and i need a tweak to modify the max lenght of file tht windows allows .
OK..here is the program now
I am given a notepad which contains many lines of text ( around 10000 lines )
now i need a code for finding the length of every line in the notepad and if the length exceeds a particular number that LINE shuld be copied in another notepad file.
Prog Lang : Java
19000 Members & Counting ....
Click Here To Join India\'s Second Largest Community
http://www.sansite.info/
Wizard is offline
Old 29-12-2004, 04:56 PM   #2 (permalink)
wat do u want this for??!!?!?!
u may use programs such as tweakui. They can handle much of the tweaking job!
futuristically_ancient is offline
Old 29-12-2004, 07:23 PM   #3 (permalink)
Need it for my Project ...
And i want u to tell me the xact tweak for this....be it software or registry tweak.
Wizard is offline
Old 29-12-2004, 08:26 PM   #4 (permalink)
Default Re: Tweak & Code needed urgently
Originally Posted by Wizard
Hello
[/color]
huh ? Unless ur on Windows 98 this isnt a problem in Windows 2000 onwards mate. I should know since I have mp3 files with really long names. Checked both in 2000 and XP works fine no long filename issues. So dont really see the problem ?!
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 29-12-2004, 10:26 PM   #5 (permalink)
Hello.
My Office system uses Windows 98 and it doesnt accept long filenames..
So i need code for tht to convert it to short names or need a tweak for tht to make it accept long file names
this help is needed from u people asap
Thanks
Wiz
Wizard is offline
Old 30-12-2004, 01:43 AM   #6 (permalink)
hafees's Avatar
i dont know whether windows2000 has such a problem.
hafees is offline
