Old 29-12-2004, 01:42 PM   #1 (permalink)
Default SDRAM or DDR SDRAM
Dear friends,
Please clarify me about RAM fandas!
I am having P-3, 650 Hz, 128 SD RAM @ 100 and also 133 sticks.
I am told that the better RAM is DDR SDRAM. I am also told that SDRAM and DDR RAM are not interchangeable. Either I have to fix SDRAM stick or DDR RAM Stick but both cannot be simultaneously..
I wanted to upgrade to 256 MB DDR Ram @ 400 Mhz.
Will this 256MB DDR Ram 400@Mhz Ram compatible with my PC configuration? Will these new stick be fitted into the SDRAM slots?
Also what is the difference between SD RAM and DDR SD RAM?
please mail me at nkmadhi@rediffmail.com
nkmadhi
C
Naba Kishore Madhi is offline
Old 29-12-2004, 02:40 PM   #2 (permalink)
King of my own Castle
freshseasons's Avatar
No the Sd ram cannot fit into the DDR Ram slot ..
DDR ram has twice the speed of SD ram..the main difference
Sd ram has 168 Pin connector
While DDr has 184 Pin connector so you cannot upgrade the same on your present motherboard.
freshseasons is offline
Old 29-12-2004, 03:34 PM   #3 (permalink)
Default DDR RAM/ SD RAM
Many Many Thanks freshseasons.
Wish you a very happy new year.
