Old 29-12-2004, 09:44 AM   #1 (permalink)
Default Display Card under 3k
which display card ( 128 MB AGP ) should I buy ...... my budget is Rs.3000
vishal is offline
Old 29-12-2004, 01:37 PM   #2 (permalink)
Default Laminton Road
I know you can geta GeFOrce 256MB for about 3k at laminton road. I'm not sure of the model number
Sachin
sachinc is offline
Old 29-12-2004, 02:32 PM   #3 (permalink)
Hey !! I'm also interested in a good cheap GPU...Tell me where exactly it's available & model number.....
Down to Earth, Still above U all....
dspawar is offline
Old 29-12-2004, 04:09 PM   #4 (permalink)
nVidia FX5200 or ATi Radeon 9200.
pimpom is offline
Old 29-12-2004, 07:04 PM   #5 (permalink)
Need more suggetions
vishal is offline
Old 29-12-2004, 07:21 PM   #6 (permalink)
In that price range these are the only cards left.And what pimpom suggest is ur best option mate!
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 29-12-2004, 08:57 PM   #7 (permalink)
Laptoping
Sourabh's Avatar
XFX GeForce 5200 128/256 mb versions are available within ur budget at Lamington Road in Mumbai
these are decent enuf cards and can satusfy normal gaming needs for the present games
Sourabh is offline
Old 30-12-2004, 01:57 AM   #8 (permalink)
I just bought a XFX GeForce FX 5200 for Rs 3000 from Nehru Place, Delhi.
There are many local brands available too but always go for a good brand because it gives you much more support than the local brand. I have got a 3 yr warranty with that card but others could only give a 1 yr warranty. You have to look into some shops before you hit the right one.
A program is a device used to convert data into error messages.
samrat_chak1 is offline
Old 30-12-2004, 10:57 PM   #9 (permalink)
For as little as 3000 bucks, your best bet would have to be the Geforce Fx5200, if you want a dx 9.0 card, which I am sure is what you are looking for.
Major-Minor is offline
Old 02-01-2005, 07:00 PM   #10 (permalink)
In pune the xfx geforce fx 5200 (128mb) card is for Rs. 2850 only
amey_dude is offline
Old 02-01-2005, 09:31 PM   #11 (permalink)
Ethan_Hunt's Avatar
Well If Its The Ati Series Then The Radeon 9200SE With 128MB DDR Vram Would Be Even Worth Considering.....It Can Range Anywhere from 2,499 to 4,999 Depending On The Area Of Purachase And Capacity To Bargain 8)
Ethan_Hunt is offline
