Old 12-11-2006, 05:43 PM   #1 (permalink)
very very STUPID
kerthivasan's Avatar
Default Unicode , Ucs ?
Actually What R Unicode , Ucs And Utf?
What Is The Difference Between Them And Y There R These 3 Instead Of One?
Please Don't Pirate!
kerthivasan is offline
Old 13-11-2006, 08:00 AM   #2 (permalink)
adit_sen's Avatar
Default Re: Unicode , Ucs ?
Unicode is a industry standard which allows text / characters / symbols from nearly all writing systems of the world to be represented or manipulated by computers / electronic media.
http://en.wikipedia.org/wiki/Unicode
UCS is the Universal Character Set, which is a character encoding of the Unicode that contains a very large database of abstract characters, each identified by a name and a corresponding integer.
http://en.wikipedia.org/wiki/Universal_Character_Set
UTF is the Unicode Transformation Format, which is another character encoding of the Unicode to support a large range of characters. The basic difference between the UCS and the UTF is that initial encoding / characters of the UTF are same as the ASCII standard.
http://en.wikipedia.org/wiki/UTF-8
Hope this helps...
Cheers
Aditya
AMD 4400+ X2; Compaq Presario M2202TU; Dell Inspirion 500m; Windows Vista Ultimate
adit_sen is offline
