Old 28-12-2004, 08:14 PM   #1 (permalink)
Mobile Freak
reddick's Avatar
Default Multiple OS in one PC
Hey...
Anyone know how can i install Win98SE and WinXP in one PC ?(or Win Me)
I know it is possible...but HOW???
Plz tell me in details
Hope 4 d best n Do d right :)
reddick is offline
Old 28-12-2004, 08:22 PM   #2 (permalink)
First install the older OS First (in your case first install win98 SE)
By default it installs in C:
After that install WinXP on a different partition or new partition say, D:
You will automatically get the boot menu once installation of Win XP is over.
Million's Of Open Minds Can't Be Wrong!
http://nc.xmgfree.com/weblog
Everybody Wants to go to Heaven...But nobody wants to Die! :wink:
naveenchandran is offline
Old 29-12-2004, 12:06 AM   #3 (permalink)
naveen is completely correct
i would like to add that while installing XP make sure you choose the option for a new installation and not for an upgrade
it is always better to install different os on different partitons so if you dont have more than one partition use partition magic to make new partititon for Windows XP or if your harddisk is completely clean then you can even use fdisk utility of MSDos, i will say get someone who has information on such topic while installation
\"I was born INTELLIGENT
But EDUCATION ruined me!!!!\"
AMD 64 3200+(Winchester), MSI RS480M2-IL, 512*2 DDR400 Hynix, Segate 80 GB SATA, LG E700SH, i-benz with Intex PS (400 W)
technoteen is offline
Old 29-12-2004, 07:19 AM   #4 (permalink)
Mobile Freak
reddick's Avatar
Wht r d other precautions needed 4 better results
Actually , a frnd of mine even crushes his HDD while this type of installation
That's why I'm not sure frm ur replies..!
reddick is offline
Old 29-12-2004, 09:46 AM   #5 (permalink)
hmmmm.....
Don't worry nothing will happen to your harddisk! :roll:
Old 29-12-2004, 10:32 AM   #6 (permalink)
i got two words for u . . . . . CHILL OUT !!!!
Nutin will happen to ur hdd.
Jus install the two o/s on two different partitions!
futuristically_ancient is offline
Old 29-12-2004, 11:07 AM   #7 (permalink)
first install 98 in c drive than the boot pc on bootable and the select d: for installtion of xp sellect option properly
sheladiya chetan
chetan is offline
Old 04-05-2007, 07:49 PM   #8 (permalink)
Default Re: Multiple OS in one PC
Thanks, I didnt think it was so easy
CoolDivya
http://www.Upload27.com - Upload files and images upto 2GB with a Realtime Progress bar, absolutely FREE. No registration required.
cooldivya is offline
Old 04-05-2007, 10:15 PM   #9 (permalink)
manishjha18's Avatar
hey any way to install vista and xp on same pc--- i know this has been asked earlier also but it was very complicated
manishjha18 is offline
Old 04-05-2007, 10:33 PM   #10 (permalink)
The Devil's Advocate
iMav's Avatar
complicated its the simplest thing to do ... its like installing winamp...
have an empty ntfs partition ... run vista setup it will ask u whether u wanna upgrade or make a fresh install .... select fresh install and select the emoty ntfs partition ... vista will take care of the rest
http://beingmanan.com
iMav is offline
