Results 1 to 8 of 8
Thread: IP header field
12-11-2006, 12:43 AM #1Apprentice
- Join Date
- May 2005
- Posts
- 87
IP header field
If we are usign a raw socket to access IP layer directly from the application layer bypassing the transport layer, I wonder what the PROTOCOL field in the header of an IP packet will contain.
Any experts know this?Attack ur enemy when he does not expect u, appear where u r least expected.
12-11-2006, 01:14 AM #2
Re: IP header field
WHat do u mean by raw socket? ANd how can u bypass transport layer? U cannot defy the working of TCP/IP protocol suite!
Even when u use loop back address the packet goes to network layer. So please elaborate clearly so that I can ponder over it!Bad Bad server.....No candy for u!
13-11-2006, 12:39 AM #3Apprentice
- Join Date
- May 2005
- Posts
- 87
Re: IP header field
Forget the concept of raw socket.
have you heard of OSPF a routing protocol? It used IP directly without using either TCP/IP
It is possible to bypass these layers as per my knowledge using UNIX sockets you can even talk to Data link layer directly. I.e. you will have to design your own protocols in that case
But I am happy that there is someone who is interested in deep knowledge of TCP/IP. I hope I ll get a good solution from you.Attack ur enemy when he does not expect u, appear where u r least expected.
13-11-2006, 01:53 AM #4
Re: IP header field
Yea man I know about Open Shortest path first!
Nops. That will rip off the whole TCP/IP protocol suite and foundation of internet! The thing u shud understand is
Originally Posted by akshar
1. OSPF is a routing protocol. And all routing protocols work at network layer
2. IP is an integral part of TCP/IP. If there was only IP then there wud have been no concept of file downloadings! We have to associate TCP with IP for that!
Have u heard of OSI model?? And why only 5 of its layers are used in practical TCP/IP model?? OSI is the complete thing theoretically! But practically its 2 layers aren't of much use practically. Hence we have TCP/IP suite, a practical model. So even if u develop ur own models, u may be combining the tasks of the layers. But theoretically and practically speaking, u can't bypass any of the layers.
If u wanna get a good detail of it then read TCP/IP or Telecommunication networks by Forouzan!
13-11-2006, 06:31 AM #5
Re: IP header field
Hope 4 d best n Do d right :)
17-11-2006, 12:32 AM #6Apprentice
- Join Date
- May 2005
- Posts
- 87
Re: IP header field
Ok. Mr. Mediator I am very glad that you paid so much attention to my question. If you have access to the book UNIX network programming by STEVENS Volume 1, read the chapter no. two. Also go through its exercise from where I got my question.
I perfectly understood what you are trying to say and that is what I use to think. But that is not the situation precisely.Attack ur enemy when he does not expect u, appear where u r least expected.
17-11-2006, 02:54 AM #7
Re: IP header field
Fine, I'll go thru it wheneva I'll have the time. And Mr.Akshar forget the Richard Stevens, and read Forouzan in detail. Its all u need to make ur concepts crystal clear. SO read it and then tell whats the situation precisely.
19-11-2006, 01:03 AM #8Apprentice
- Join Date
- May 2005
- Posts
- 87
Re: IP header field
I have read Forouzan many times and I don't think my concepts are weak. If you doubt that my question was not so clear check Stevens
USB Header to USB socket cable
By patkim in forum Hardware Q&AReplies: 8Last Post: 23-06-2012, 10:15 PM -
Want to Insert Header and Background in Forum ?
By satyamy in forum Internet & WWWReplies: 3Last Post: 25-09-2008, 08:42 PM -
Azureus giving problems:Bad Header
By rocker in forum Software Q&AReplies: 2Last Post: 12-07-2007, 10:46 PM -
Zidane's header!!!
By nik_for_you in forum Random NewsReplies: 3Last Post: 10-07-2006, 06:36 PM -
corrupt avi header !!!
By atool in forum QnA (read only)Replies: 4Last Post: 07-06-2005, 12:25 PM
LinkBack URL
About LinkBacks
