Old 11-11-2006, 07:21 PM   #1 (permalink)
Default bluetooth problem
hi guys,
I renamed the bluetooth of My N70 as given below
asdf (tab space) dfdfg (tab space) gfgsfgs (tab space) gfgsfgs
now the problem is I can't open my bluetooth settings of N70,
how can I fix this problem without a reset or a format?
please help me soon
Raaza is offline
Old 12-11-2006, 12:24 PM   #2 (permalink)
Kiran.dks's Avatar
Default Re: bluetooth problem
What exactly you went on to do with that kind of renaming?
Kiran Kumar R
Kiran.dks is offline
Old 12-11-2006, 01:06 PM   #3 (permalink)
if someone search and send any message to my phone via bluetooth, his phone will restart, this was the trick, in order to do this ,need to rename bluetooth as done, that's why i renamed so.
A friend suggested me coz he used to this trick with his 6680 very successfully.
Raaza is offline
Old 15-11-2006, 12:30 AM   #4 (permalink)
Does that trick really work
There is a very fine line between genius and insanity. I have erased this line.
freezer is offline
Old 15-11-2006, 06:12 AM   #5 (permalink)
Mobile Freak
reddick's Avatar
Nope...it fails on my N70 too
Hope 4 d best n Do d right :)
reddick is offline
Old 15-11-2006, 07:35 AM   #6 (permalink)
Kiran.dks's Avatar
Ok..I never heard of that trick. But ofcourse naming it to such a lengthy name may provoke a restart. Once I saved a number with a very lengthy character and tried to save it. It got saved, but when I tried to call that number, the phone restarted.
So this is character compatibility issue. And that's why I think you are not able to open ur Bluetooth settings.
Rename it back to simple name and try opening the settings.
Kiran Kumar R
Old 15-11-2006, 10:21 AM   #7 (permalink)
De@d
outlaw's Avatar
me too
never heard of the trick
i renamed the bluetooth in my n70 and i still can access the bluetooth settings
no problem whatsoever
Man's greatest living fear - When you die, they will find your porn"
Most people are only alive because it is illegal to
shoot them.
outlaw is offline
