Old 10-11-2006, 01:48 AM   #1 (permalink)
sauravktr's Avatar
Exclamation System Restart Automatically !!!
My system restart automatically when i try to open folders in Explorer.But it happens often.That folder opens next time smoothly but the problem sticks with another folder.I scan my computer with AVG 7 & McAfee Antivirus(Latest Updates).Also scan with Ad-aware SE & Stinger But the problem remains same.Also formatted the system once.Plz Someone help Me Out
sauravktr is offline
Old 10-11-2006, 08:01 AM   #2 (permalink)
Default Re: System Restart Automatically !!!
Turn off automatic restarting on crash (Right-click on My Computer->Properties->Advanced Tab->Startup and Recovery Setting button->Uncheck Automatically Restart) and look at the error code in the BSOD... Post it here...
Arun
sakumar79 is offline
Old 11-11-2006, 02:02 PM   #3 (permalink)
[A]bu's Avatar
That may be the virus. u may opened any antivirus software or the folder named such software such problems comes. Try any other task manager and see what happens.
[A]bu is offline
Old 12-11-2006, 10:02 AM   #4 (permalink)
tuxfan's Avatar
I had a similar problems earlier and the problem turned out to be a faulty power supply
tuxfan is offline
Old 12-11-2006, 10:34 AM   #5 (permalink)
gooby pls
Third Eye's Avatar
@sauravktr: May changing PSU will solve your problem.
Third Eye is offline
Old 12-11-2006, 11:14 AM   #6 (permalink)
An Esoteric Geek
sridatta's Avatar
I have faced the same problem in VISTA RC1 when i open a folder containing media. The explorer just crashes up.. and next time when i open the same folder it works fine.. but the problem sticks to other media folder.. This was the problem with many of my frenz systems too.. donno why.. Is there any bug reported??
sridatta is offline
Old 12-11-2006, 06:16 PM   #7 (permalink)
very very STUPID
kerthivasan's Avatar
Try Opening The File In Anpther Computer And If U Find Fault In That Computer Also Then The Prob. Is With Ur Media File.
Otherwise It Is With Ur Power Supply As One The Members Told Above
Please Don't Pirate!
kerthivasan is offline
