Ah!! Of course it won't work
Go to
http://www.statcounter.com, register there and put the code they give you in the right place. Then the counters will start working
Statcounter is free, but you should not have more than 100 visitors per day. If you have more visitors than 100 per day then they won't ask for money, but the counter will not be accurate. Just check on the site what happens.
