Old 09-11-2006, 11:28 AM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Inernal 2 External ! ! !
i have a internal sony DVD riter ...... can i make it work as an external drive ?
ie connecting via USB port , any EXTRA hardware ......... suggest me plz ........ will have 2 buy from lamingtone road .......
any good shop ?
ax3 is offline
Old 09-11-2006, 11:33 AM   #2 (permalink)
Come get Some
DukeNukem's Avatar
Default Re: Inernal 2 External ! ! !
yes you can, try the external casings for same.
i've Made my cdRw external using external hdd casing
Computers are like Air Conditoners, thet stop working properly when u open WINDOWS.
DukeNukem is offline
Old 09-11-2006, 12:29 PM   #3 (permalink)
tuxfan's Avatar
And the casing costs just about Rs. 600-700 at Lamington Road
tuxfan is offline
Old 09-11-2006, 01:29 PM   #4 (permalink)
ax3
ax3's Avatar
thanx a lot .... bt any company or specific model 2 buy ?
& 600-700rs is 2 gud ..........
ax3 is offline
Old 09-11-2006, 06:53 PM   #5 (permalink)
tuxfan's Avatar
I haven't myself purchaesd it so no research done for it and therefore don't know about company/brands. But I have seen it in a few shops there. I just asked the price out of curiosity
tuxfan is offline
Old 09-11-2006, 07:04 PM   #6 (permalink)
apart from casing...nowday IDE to USB 2 converter is also available, which are cheaper. there is also a ac power adapter accompanying with it.
see this http://www.techtree.com/India/TECH-C...68481-611.html
jack// ani is offline
