Old 07-11-2006, 12:11 PM   #1 (permalink)
Alive Again...
satyamy's Avatar
Question Indexing Service.....?
I saw Indexing Service Option in Every Drive
Can anyone tell me Exactly wht is Indexing Service & What it do......?
satyamy is offline
Old 07-11-2006, 12:21 PM   #2 (permalink)
Default Re: Indexing Service.....?
Indexing service helps in speeding up your file searches. If you have a lot of data on your system or if your system data is disorganized, and you find yourself regularly using the search feature, it is recommended to have all partitions indexed. Otherwise, you can turn off indexing... Turning it off will possibly lead to a minor increase in performance, though this may not be appreciable...
Arun
sakumar79 is offline
Old 07-11-2006, 12:49 PM   #3 (permalink)
Come get Some
DukeNukem's Avatar
What indexing service do is to catalog each and every file present in you hdd. when you search for a file windows search for it in this catalog thus giving you lightning fast results (rather than searching it in the Hdd).but it has some drawbacks (depends on user to user ), will cause overhead as it has to catalog everything thus makig pc a bit slow.
and enabling "Indexing Service" Option in Every Drive alone wont do it, one must have "Indexing Service" enabled( from services.msc) and running for it to serve its purpose.
if you have tons of tons of tons of tons of tons of tons of files in your hdd which needs to be searched on regular basis, then use this usefull feature
if u are not a search maniac then you can safely turn the indexing service off( from services.msc).
Computers are like Air Conditoners, thet stop working properly when u open WINDOWS.
DukeNukem is offline
Old 07-11-2006, 12:58 PM   #4 (permalink)
Though Indexing Service makes searches faster, but sometimes it makes computer very very slow, while indexing files it eats a lot of resources.
govind@PH4 is offline
Old 07-11-2006, 02:27 PM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
And I always remove it completely from the Setup using nLite
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 07-11-2006, 03:21 PM   #6 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Me2 the same
rakeshishere is offline
Old 07-11-2006, 04:11 PM   #7 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
Thumbs down Re: Indexing Service.....?
Yup... off the indexing service, it sucks.
Resource wastage, if u know where u put ur acorns.
But no need of NLite or stuff like that.
It's a Windows service and can be disabled by running services.msc
In the window opened, hunt for Indexing Service, double-click it.
In the General tab, in the Start-up type, mark Disabled. Close.
Kaam khatam.
koolbluez is offline
Old 07-11-2006, 11:42 PM   #8 (permalink)
Alive Again...
satyamy's Avatar
thanks a lot friends
satyamy is offline
Old 08-11-2006, 12:11 AM   #9 (permalink)
Indian by heart
planetcall's Avatar
indexing makes your searches way faster. So, if you need to search a particular drive frequently or u contain a lot of ebooks and need to search it regularly etc..then you would like to have indexing enabled for that particular drive.
प्रासादशिखरेऽपि सन्न काको गरुडायते ॥
No matter how high a fool may rise, he remains a fool -RigVeda
planetcall is offline
