Old 07-11-2006, 12:00 PM   #1 (permalink)
Alive Again...
satyamy's Avatar
Question File take ages to open
Some file in my PC which are in .cdr(coreldraw) format takes ages to open
they are of just 2-3MB's
even a file of 10mb takes just 30sec to open only some of these particular files takes ages to open
I can't delete these files because they are very important for me
also while opening these files my CPU usages goes to 100%
& tired these file in many other PC's & also in some of my friends PC's
there also it gvie the same prob
So i came to conclusion that these file are corrupt & there is no prob in my PC
i think these files are gone corrupt after opening they show me all the work & data as it is & works fine
only thing is it takes ages to open
pls help.............
wht to do now to solve this.................
satyamy is offline
Old 07-11-2006, 02:48 PM   #2 (permalink)
Cool Buddy's Avatar
Default Re: File take ages to open
I'm not the expert but still would like to help as you haven't got any replies!!
Try copying all the contents of the file in a new one and save it. I'm not sure if this would help.visit Here For help.
Cool Buddy is offline
Old 07-11-2006, 05:53 PM   #3 (permalink)
Can you not convert to different format and use it?
Arun
sakumar79 is offline
Old 07-11-2006, 11:39 PM   #4 (permalink)
Alive Again...
satyamy's Avatar
thanks for replying
no i cant convert it into any other format their is no option like that
i had taken a full backup of my HDD in some DVD's reformatted, repartitioned it but was of no use
after copying my files again into HDD it gives same headache
satyamy is offline
Old 08-11-2006, 10:17 AM   #5 (permalink)
kl_ravi's Avatar
Which is your default Image Viewer/editor handling the *CDR files what is the image resolution of that image, Have you tried opening it with Irfan view & converting it to other format
Everything that follows is a result of what you see here...!!!
kl_ravi is offline
