Originally Posted by nitesh872004
But I can't use administrator account of the pc. I can use only user account. Now can I delete that file with unlocker??
are u the owner of that pc ?
or a stalker ?
why keep password so protected that they are protected from yourself
brother you just cant delete sam file while using windows
is your partition fat23 based ? yes there is a simple solution
boot from external sources i.e bootable floppies, cd's (i.e win98) and then delete the sam file
else if NTFS based try recovery console (u cant as u forgotten admin pass )
or download the file below burn it on cd(after unzipping it. its an iso, dont jus copy it to the cd but choose burn image option instead), boot from it and reset the admin password
http://download2.lsoft.net/boot-cd-iso.zip
